I have a 89 LX 302. I have a 73MM C&L MAF. I need to know the model # for the senor that I should use. The one thats on there right now is E9ZF-12B579-AA
AFH55-03
Thats the thing I didn't put any of these mods on here. They were here when I bought the car so I dont know if it has the correct sensor or not. I do know Ford said the new # for that number I posted isF1ZZ12B519AARM. I called them with that # you gave me and they said they need more #'s or info. I am not sure if it will work or not but I know where theres one on a T-Bird that has a 5.0HO
What sensor you need will vary with what computer you are using.
If the PO installed an X3Z computer you will need a different MAS than if you have an A9L computer.
First thing to do is verify the computer catch code.
When I get home tonight I will verify the sensor you need and see if I can find some other applications.
Ford asked for the full part number because that is what their system demands. The first 4 digits are enough to determine if the sensor is appropriate or not as they specify the 'calibration' so to speak.
I have a A9L computer and if its true that I need a F1SF one my first 4 digits are E9ZF which Ford says it now has a new number but it still isn't that number you gave me. The number mine crosses over to is F1ZZ. So yes if you could check tonight or if someone else out there knows feel free to jump in.
Ah, Ford is revising their part numbers...
That makes it difficult, as now we have to look for the old part numbers in the junk yards, and look for the new part numbers when ordering NEW replacement parts.
If Ford is telling you that the F1ZZ is correct for your computer, then I would go with that.
The info/notes I have at home are focused on finding j/y parts...
In all honesty I dont know if its right for my computer or not. All I did was call Ford and gave them the part # on the MAF sensor and aked for what kinda vehicle it was for and he said that part # had changed and he gave me the new part # and he said its for a mustang but thats it. Thats all he told me. He didn't say what computer or whether it was for a 8 cyl or 4 cyl or nothing.
