  • SN95 4.6L Mustang Tech
which oil do you use. I am debating
  • Thread starter Thread starter shawnaj7731
  • Start date Start date Feb 22, 2006
1 of 2 Next Last
shawnaj7731
12
  • Feb 22, 2006
I have an 01 bullitt with 25k I am going to do an oil change and have been debating on what oils I should use. Syn or not . Should I use lucas oil synt oil stablizer or not. I was told to use 4 qts of 5w30 with 1 qt of the lucas stablizer. What are you guys opinions or what do you use.
G
gotchopsticks
315
  • Feb 22, 2006
well i used 6 quarts of 5-20w Syntec, and it has lasted me 5,500 miles and the oil is still light brown. it is clean every time i change it, no debris, and i thank the motocraft 820s for that. syntec
J
Justin03GT
199
Mount Pleasant, SC
Feb 22, 2006
  • Feb 22, 2006
synthetic...one of the high end brands like castrol or mobil one...i change mine every 6-8k and it comes out cleaner than 3k dino oil..
sgarlic
3,085
Feb 22, 2006
  • Feb 22, 2006
I use Motorcraft 5w20. Over on the BITOG forums, there's a thread with a test of how Lucas affects your oil. It showed it to cause foaming.. I for one won't be running it.
M
Mindstatic Pro
107
INDY
Feb 22, 2006
  • Feb 22, 2006
I use full syn Mobil 1 5w30 and a motorcraft filter. Just my .02
the98stang
2,408
Clovis, CA
Feb 23, 2006
  • Feb 23, 2006
Don't put ANY Lucas in your engine. That car doesn't need it...especially since you only have 20k miles. Lucas is used on engines with high mileage (100k +).
I run 5 quarts of synthetic Mobil one 5w-30. You can get it at Walmart for DIRT cheap (it's a 5 court jug thingy). They even have the right Motorcraft oil filter. You could also run 5w-20 I suppose.
I'm not sure why every one is posting 6 quarts of oil . My 2000GT owner's manual says 5 quarts with a new filter. With 5 quarts, the oil reaches the "MAX" mark one my oil dip stick. Put 5 in there, and if it's not enough, add more.
sgarlic
3,085
Feb 23, 2006
  • Feb 23, 2006
Yea.. the older models for some reason take more usually. My 04 takes just about 6 quarts to get to the full line.
the98stang
2,408
Clovis, CA
Feb 23, 2006
  • Feb 23, 2006
You mean the older models take less oil lol....I know what you mean
sgarlic
3,085
Feb 23, 2006
  • Feb 23, 2006
Yeah.. I guess I meant the LATER models.. newer.. whatever.. it's late.
Crzyhrse
Seattle, WA
Feb 23, 2006
#10
  • Feb 23, 2006
  • #10
Mobil 1 5W-20 Synthetic.
hotrodnut
672
North Florida
Feb 23, 2006
#11
  • Feb 23, 2006
  • #11
Same here.
No matter what it reads on the stick it should take the specified amount from the Factory, i.e. 6 qts. The dip sticks are notorious for being off and on my Mach it is a little low after a fresh change. I scribbed a line on the stick so I would know where it is "supposed" to be after a fresh change and then between changes I have a solid point at which to go by when checking.
04gtdrop
532
Sac, CA
Feb 23, 2006
#12
  • Feb 23, 2006
  • #12
its a little over kill but i use amsoil 5-30w and i change it about every 5k miles. i was changing it every 3k miles. but it got to be a PINA. so now i do it about every 5k or so.
merc123
420
North GA
Feb 23, 2006
#13
  • Feb 23, 2006
  • #13
Mobil 1 or Ford 5w-20. 6 quarts. I change either every 3k or every 5k depending on my mood. There really isn't much color difference when i change it at 3k and when i change it at 5k
Hammer1999Gt
169
Toledo, OH
Feb 23, 2006
#14
  • Feb 23, 2006
  • #14
I was using Amsoil for the last 2 years changing the filter every 3k-5k and chaning the oil every spring when I get the car out of storage. I only put about 9k on a year. This spring I am going to try Mobil 1 5w-30 because it was cheaper at Walmart than Amsoil. Also only one place around here sells Amsoil which is a PITA. I also use Motorcraft filters.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 23, 2006
#15
  • Feb 23, 2006
  • #15
Motorcraft 5W-20 synthetic blend with Motorcraft FL-820S filter just like it says in the owner's manual. Remember the filter selection is just as important as the oil selection...
98blackmagic
386
wouldnt you like to know
Feb 23, 2006
#16
  • Feb 23, 2006
  • #16
Me too , sure is high priced I just paid 5.20 a quart
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 23, 2006
#17
  • Feb 23, 2006
  • #17
i use the ford 5-20 oil right out of the pump. it's free and in my bay. i cange my oil about every 2-3k miles. one time i was bored at work on a slow day and canged out oil that was in there 500 miles <---- thats overkill
98blackmagic
386
Feb 23, 2006
#18
  • Feb 23, 2006
  • #18
I believe in the old saying, you get what you pay for. Dont you?
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Feb 23, 2006
#19
  • Feb 23, 2006
  • #19
Depends on how I'm feeling... Sometimes I use Wesson, other times I'll use Mazola.
J/K
I run Mobil 1 10W30 full synthetic and a Mobil 1 M-210 synthetic filter.
U.M.
J
joekd
51
#20
  • Feb 23, 2006
  • #20
Mobil 1 full synth with a Purolator pure one filter here
1 of 2 Next Last
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Lifter tick
  • Creomod
  • Oct 31, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2024
Creomod
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
