Which roller rockers clear SN95 valve covers.
Which roller rockers clear SN95 valve covers?
Looking for a list of stud roller rockers that will clear our stock SN95 valve covers without modification of valve cover or the rocker arm, though I realize that may be asking too much. I need a 1.6 rocker that clears with a .550 lift. (at the valve). The Comp Cams Magnums look like a candidate. Interested in aluminum rocker choices as well.
Stang D said:
Fox valve cover fits under a Performer Intake?
Almost 100% sure and you won't need a spacer :nice:
Search using these names because, IIRC, they use the regular Edel and I know some of them used Fox vc's
Rockin Rick
GT Jake
Hairy Canary/Rootus (same guy)
A search using Fox valve covers will also have to turn out a lot of threads as I know for sure, I've seen a ton of em over the years.
Grady
Thanks Grady, I'll try some different angles on my searches. I have read lots on the subject. But most involved ball peen hammers, grinders and stuff like that. Didn't think to search for fox covers. Just hoping for a couple options that go under the Fox covers. I know Dave said his intake was getting shined up by the hood isulation without intake spacers. I'm good with the steel Comp Cams Magnums in any event. Nobody's gonna see sexy aluminum rockers once it's buttoned up anyhow.
I have seen Vibe say you can buy chrome vc's from some place that work pretty good also.
Sorry, don't remember the details but you will see this option turn up in your search I bet.
Grady
