Which Royal Purple ATF?
Hey all-
I'm looking to replace my T-45 fluid with some Royal Purple ATF- For those of you that like/are using RP, wanted to see which ATF you are using.
I see the "Max ATF" is recommended for Ford Mercon automatic transmission applications-
The "Synchromax" is recommended to manual transmissions that specify ATF, but says nothing about Ford Mercon applications.
I'm guessing that "Synchromax" is what I should use, but I figured I would ask before I put in an order-
Thanks!
Adam
