Which SBF cylinder heads?
Which Cylinder heads for my '67 c-code 289?
  • AFR 165cc
    Votes: 16 40.0%
  • TFS Twisted Wedge
    Votes: 8 20.0%
  • World Products Roush 200
    Votes: 1 2.5%
  • World Products Windsor Jr.
    Votes: 2 5.0%
  • Ford Racing GT-40 TurboSwirl
    Votes: 2 5.0%
  • Ford Racing GT-40P
    Votes: 2 5.0%
  • Edelbrock Performer RPM
    Votes: 9 22.5%
  • Edelbrock Performer 5.0
    Votes: 0 0.0%
  • Total voters
    40
Definately one thing to consider between TFS and non TFS heads are with the TFS, you can have 2.02/1.6 valves while you have to stay with the smaller valves on the other heads to work with your stock pistons. The TFS heads are definately better flowing than the AFR 165's. If you're comparing to the 185's it's close to even (TFS has more low lift flow, max lift flow isn't everything) but I believe they come with the larger valves you can't fit. TFS heads are also fairly cheap for aluminum heads. Summit has them for $1150. They should have the best price since they own Trick Flow. They come normally with 170cc intake runners but can be opened up to 205cc or possibly more without a problem for future growth. You can even buy CNC ported 205cc intake TFS heads from Summit for about the same price as the same size AFR's and the TFS ones will outflow.
-Brian
