Which Transmission?
jackchan
507
Mobile Alabama
I know this has been raked over 1000 times, but what I want is Simplicity, value for a dollar, and I want the thing to hold up, be easy to install, be cost efficent, and shift smooth even after thrashing on it at the track from time to time.
I currently like the way a T-5 shifts, and ease of installation, ease of rebuilding, and the fact that you can use stock bell, stock type clutch, clutch arm etc etc.
basically what I want is a trans that will hold up to 11 sec passes at the track on good tires, shift smooth and last.
I know of plenty of people who have broken TKO's etc. But these were older transmissions, not the newer 500 and 600 series trans. I'd love one of the Viper T-56's but would they hold up to racing and still be smooth on the street...then there is the fact of how much extra parts would you have to buy to install a TK 500-600 or T-56?
and last but not least
I dont want my trans to sound like its a road racing trans.......i.e. I dont want the straight cut gear sound coming from it.
any help will be greatly appreciated
Jack
so what all would i have to change for a tremec TKO or better?
1) trans
2) bellhousing
3) clutch
4) shifter
what about driveshaft collar? what about crossmember? I worked on one long ago but most of the cars we worked on were either AOD, C-4 or T-5! So I dont have very much experience with the Tremec's.
thanks
Jack
I'm gonna stick with a T-5! I have two, one that needs rebuilding. One that is ok to run. I dont think I will be making over 300-350 hp anytime soon. IF i do then I'll go C-4 automatic. Until then I'll just rebuild a T-5, put a good shifter on it and keep a spare around. Unless I just get stupid with it... I cant see it being a big problem, especially on street tires, with the occasional romp at the track with some bfg drag radials or something. I don't power shift that often. So I should be fine.
thanks
Jack
