Which wires going to the ALT. should have power at key on engine off??
juiced_94gt
1,143
Southern California
With the key on and the engine off the middle wire on the big plug and the power wire have voltage, the small plug doesen't :shrug: is that how's it's supposed to be?? I took the ALT to autozone and it tested fine, im going to fire up my car this weekend and I repaired a little bit of wiring so hopefuly that fixed my charging issue as the ALT is good, please which wires should have power with the engine off.
White/yellow (labeled A on your regulator) and the charge cable should float battery voltage with the key-off.
