i did the 25 point surge checklist deal before. i got clear down to finding out my alternator was fried. i just replaced it with a new 95 mustang 130 amp from cut rate. idle problem went away.
in the process of trying to fix the surging then, i had tinkered with tps adjustments and cleaning iac, cleaning maf, clocking maf, fuel filter, cleaning sensors, ect.
so it idle'd pretty high with the alt in there. i also developed a hanging idle. i read and came to the conclusion i'd set tps voltage, disconnect battery, then turn back idle screw and set it from there.
i did this, got it idling, set it at 750 to start, ended up moving from 800ish to 1000 rpm idle via my saleen cluster. so im guessing 950ish rpm with a trickflow stage 1.
idled GOOD. returned back down to rpm pretty well, it would ocassionally drop from 950 rpm to about 750 real quick then stabilize at 950 right after. i let that slide, took it around the block, and it was fine. then came the horrid whistling again. i looked for leaks, ect. nothing.
here is a video; YouTube - MVI 1931
after this whistle started, the car also surged when i pulled back into the driveway. i put it in neutral and revved it. it would no longer return to idle, it dropped to 500 rpm, surged to 1400ish about 3 times and died.
before the surging, when it was only whistling, i unplugged the iac and nothing changed... wtf is this?
