Who has winter projects still in the works?
Zero Signal
2,633
Tucson, AZ
My car has been down since the 1st weekend of Jan since I tore the motor down to install the combo in my sig. Looking back, I really wish I had pulled it out completely from the get-go. Especially after finding that BOTH my motor mounts were totally SHOT. The engine was even sitting sideways in the bay and I didn't even realize it. But after that and lots of screwing with the valve train, I finally got it figured out and now I'm waiting for new springs from Comp :rolleyes: and new valve covers from AFM.
I took a look at my engine wiring harnesses since I'm stuck without the springs and they had some issues (frayed injector wires, frayed sensor wires, corrosion, oil all over the main harness) so I decided to rebuild those as well.
Last weekend I got the timing cover torque'd (what a bitch to get on), lower manifold on and torque'd and the A/C + PS bracket and pumps on. So far, all without a hitch (cross my fingers). I've been tapping threads and die'ing the bolts as I go just to make sure. I also fitted the upper plenum and found that the frontmost bolt hits the hood with the 3/8" spacer (without the heat shield thing) so I took the grinder to the hood and notched a hole in the rail so the bolt won't hit at all when the motor torques on the mounts. Pluss the TF spacer kit didn't come with the right bolts for the Explorer intake. I need to find two more of those really long ones somewhere so if somebody knows where to buy those let me know :bang:
I also figured I would clean up the engine bay since I was in there. I ended up spending hours messing with things and try to remove the battery tray. I ended up having to drill out the bottom bolt to get it off :mad: only to find some nice rust underneath it from the piece of crap battery leaking :owned:
Anyway, just wondering what you guys have in the works. It always seems this kind of stuff is just one can of worms after another! The little things are frustrating but in all it's still a lot of fun. I'm so glad I bought my truck when I did :nice:
I'm trying to get it cleaned up again after the paint job. engine was covered in dust. I was planing on put my clutch and input shaft in this season, but i don't think that is going to happen. no money left....
other than that is all about cleaning it up
my car's undergone surgery since mid december. i finally dropped it off w/ the painter a couple days ago, so we are finally nearing the home stretch!
things that went/are going in:
abc exclusive body kit, new paint (black), 17x9, 17x10.5 dd bullitts, UPR clutch adjustment kit, cruise control covers, bullitt shift knob, 3.27's, cobra fog lights
only about a week and a half left of torture, then i can get 'er back.
The projects I have going on are:
- Painting/Polishing the GT40 intake, elbow, and TB
- Removed the smog equipment
- Painting or polishing the accessory brackets
- Homemade CAI
- Re-routing the engine bay wiring
- Relocating battery to trunk
- Dr. Gas O/R X
- Bilstein HD struts/shocks
- H&R race springs
- MM C/C plates
- Replacing the rack with low milage 03 Cobra unit
Thank God for school refund checks :D Now, I just need someone to help me.
I just got new foglights and the gas hood props put it in last night. As soon as a figure out my elecrtical drain and take the car out one last time, I'm pulling apart the engine to polish as much as I can and replace the timing housing gasket. I'll be relocating the battery and just cleaning up the engine bay in general. Sometime in March I'll be taking my car to Rhodes Custom Auto for a roll bar and then I'll be recovering my rear seats to match my Corbeau CR-1s.
My car has not been running since aug. '05. The motor has been out for about a month now. The block is at the machine shop and im waiting on some goodies to be sent from Brian at adperformance via Probe:nice:.
I also need to ship my heads to Ed C. to get them fixed. And there is a ton of small crap i want to do...but im not sure how much will get done.
-Sound insulation in the cabin
-03 cobra console(got it just need to install it)
-bullit accessories for the console(shifter and cup holder bezels mainly)
-Clean up everything that i can
Im hoping to be done by beginning of march...but i dont think it will happen.
Well, mine has been down since april '05 and it is still sitting in my garage in a million pieces. If I can ever make up my damn mind what I'm doing with it, maybe I'll start the buildup. I really wanted to have it up and running before our baby is born, but that isn't going to happen.
my list is so long, it is more like a lifetime project
sigh
at least the blower is in :D heck, that wasn't even on the list!
Here's my to do list:
- Install the boost gauge
- Install the sub-woofer
- Figure out a way to put the rear speaker cover back on.
- Replace the antenna and make it work
- Hook the radio up to the headlight on/off switch
- Re-glue the side mirrors so they don't shake
- Replace broken front turn signal housings
- Replace burned out bulb(s) in the gauge pod.
- Replace or fix the ripped shifter boot.
- Fix the steering problem caused by fixing the cancel on the left turn signal.
- Install cupholder mod.
- Adjust the top so the passenger door closes with the window all the way up.
- Install the fog light mod to be able to use fog lights independently of the headlights.
- Install the 120v AC transformer somewhere.
- Change badges to "302" or "5.0"
- Paint the side scoops silver.
- Paint the inside door trim silver
- Paint the car (or at least the front bumper)
- Replace the heater core
- Get the driver's seat recovered
- Replace the front amber bulbs with LED bulbs
- Fix the drip into the car when it rains
- MAYBE Relocate the battery to the trunk.
- MAYBE Install cooling vents on front quarter panels (like the M3 has)
Im still working on swapping my engine out. its just about out, but i still have to transfer the timing cover to the new engine, put the new water pump on, the manifold, oil pump, and put it all back in. I can only work on it durring the weekends, and ive been partying a bit too much lately :)
i had a bunch more mods planned for the 95 but they got put on the backburner when i got the 02
heres a pic of how it looks right now
still gotta put the sideskirts on and a few other things
got my acc. brackets powdercoated silver metalic
Got the explorer upper intake cleaned up by removing the bracket on the side and smoothing up some more powdercoated silver met., also got the t-body elbow ground down to match the upper at the t-body area and also got the elbow powdercoated.
Have the timing cover and water pump painted black.
have the 1.7rr setup
have the valvetrain geo sorted out.
have the pushrod checker adj. correctly...just need to get a final meas. and order.
99+ front calipers painted and ready to go on...waiting to order a line lock to put on at the same time.
ended up removing the A/C (that was busted anyway) and about to re-paint the engine bay black.
hope to pick up the replacement fox valve cover next week as one was cracked...should have them painted black and silver by next weekend.
just need to pickup timing gaskets, intake gaskets and put the intake and timing cover back on. Going to replace the timing chain as well...its only like 9$ for the chain...its not that its old...just why not for the price.
debating on getting the alt. powdercoated chrome or polishing it...could go either way right now its sanded down to 240 or 260 for now...thinking the powdercoat will stay nice longer though and be less work to keep clean.
Heh and I thought I had it bad!
Update us sometime if you even get that one done. I'd like to see how you did with it.
That one is way up there on my list for the Bronco. Damn thing is all rattley like you wouldn't believe.
Don't forget the pics once that one is done, I'm sure you'll be whoring those :nice:
In general for me, having the downtime is not too bad. I keep the car in my parent's driveway across town. I can pretty much only go by there ont the weekends to work on it and I take the little things back to the apt. to work on (like my wiring harnesses). I find I make really good progress with realistic goals and take it one step at a time without getting ahead of myself.
Of course you guys know Im always working on something... Still playing with this 01 ( will be DONE for the most part, by the end of February).
<b>To Do:</b>
Finish door jam, trunk, and complete exterior.
reupholster the seats with some neat custom idea. Install wideband 02, 42's and Lightning meter, and dyno it.. Then im DONE!
Everything I have to do to my car has to wait till i go home for spring break in march but this is what I have planned:
install my convertible top
complete tune-up
03 cobra control arms
and hopefully H&R SS lowering springs, MM rack bushings and MM c/c's
