who is running the trick flow stage one?
maxine1970
36
louisville KY
I've pretty much decided on a trick flow stage one cam to put in my 96 explorer engine. It is going carbed and into a 5 speed convertible 86. The engine is stock other than the cam, valve springs, and carb setup. who here is running the trick flow stage one cam and how are you performing on it? anyone running the stage two, and if so, how are you doing with it? where are the powerbands on these in your cars? mine has 3.27 gears and I want low and mid range power but I dont want it to fall on its face at 4000rpm like the stock 86 5.0 does. thanks!
doug
