Who would win between these two.
2700lb 66 Mustang coupe, manual everything, no a/c basically nothing to rob its power with 77 model 302 with flattop pistons being the only upgrade with 2100 autolite carb, C-4, 3.00 gear
or
92 Prelude V6/5spd with decent driver, bone stock
Which would be the faster car from a dig, low speed roll, high end, etc?
or
Prelude
But....for an easy upgrade strap a set of 65 289 heads on the 77 302....the chambers are smaller which will give you a big compression boost upping your usable horsepower.
I've been in almost the exact same race. Yes, all Preludes are 4 cylinders. If its a H23 (2.3) then you'll most likely win, if you're motor is tuned well. If its a H22 (2.2), sorry he'll probably get you from a roll. You will probably get the jump from the start though.
