actually ford has had several automatics of the years, starting with the original cast iron cruise-o-matic, the ford-o-matic(2spd used behind sixes), the aluminum case C4(light duty for sixes and small V8's), the aluminum case C6(heavy duty used behind the larger small blocks and big blocks), the fmx(an updated version of the original crusie-o-matic used behind small blocks in medium duty applications like 351w engines in performance cars), then of course the C3(used behind 4 and V6 engines), the AOD used in various applications, the AOD-E an upgraded and electronically controled AOD, and the 4R70W and its variants which are upgraded AOD-E transmissions. each had its reason for being.
