Why can't I use coilovers with Hotchkis C+C plates?
Hey guys I installed a set of Hotchkis 3001 caster / camber plates in my 86 a while back. I wanted to install coil overs but after referencing the instructions for the c+c's they have a note that states:
Not recommended for coil over applications.
Why?
Someone told me that it was because they use a 3 bolt (L bracket) support. However I've heard of people using coil overs on their stock plates which are also 3 bolt. I know the MM plates are 4 bolt but that's not an option now.
Any ideas???:shrug:
It is the load that the caster/camber plate has to take. With the stock suspension the weight of the car is carried by the spring on the control arm and K-member. With a coil over the weight is all on the strut, which the C/C plate is supporting. If the C/C plate is made out of aluminum, then it cannot support the load/weight of the car and it will fail.
I do not think the stock strut mount will work with a coil-over conversion. The configuration at the top of the strut with a coil-over is to large to be used with the stock strut mount..............I think. When I went to a coil-over set-up on my car, it was automatic that I had to use a C/C plate set up. Since my entire front suspension is QA1 I had no issues with fitment.
