why do i get check engine light with stock a9t computer but not a9p computer?
85cleangtvert
103
i recently bought a 89 gt 5.0 automatic. it had a check engine light when i got it. i disconnected the battery for about 15 mins, came back connected it started it and the light came back on within a few seconds. today i was in the wrecking yard and i saw a 90 gt 5.0 automatic. it had a a9p computer. i bought it just to have a spare or sell on ebay. i wanted to check if it worked or not so i hooked it up to my 89 gt. started it up, no check engine light. drove around, still nothing. runs a lot better than the a9t my car had. it looks like the a9t was stock for my car. the a9t still runs but it idles a lot higher and the check engine light comes on... what do you guys think the reason for that is? is my a9t computer bad? just to make sure i hooked it back up again and sure enough the check engine light came right on with it. what do you guys think? and what is the difference between the 2 computers.
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
