why do my rockers tick?
  • Thread starter Thread starter Mr. Rustypwnz
  • Start date Start date Feb 6, 2007
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Feb 6, 2007
  • Feb 6, 2007
yo, I put my gt40p heads on finally and started it up, I noticed it ticks, the old engine used to tick though with these rockers, so is this normal? its not loud or anything just noticeable, dosent do it with stockers on. It runs real good though the heads have made a biiigggg diff in adle quality and all, tomorrow im going for a wot run through 1-4 and see how she does. :SNSign:
josh
Jason 302
685
71
68
Newark, Ohio
Feb 7, 2007
  • Feb 7, 2007
Completely normal, mine do it too. I think its the roller on the tip, for some reason they just make that noise.
D
Daggar
3,902
  • Feb 7, 2007
I'm running the Trick Flow RRs and mine are a bit noisier than I'd like as well.
I'm considering whether I should pull it all back apart (KB and all) to ajust them down another half a turn or just say, "Hell with it" and get used to it.
Modular2v
3,222
23
99
oklahoma
Feb 7, 2007
  • Feb 7, 2007
i have to adjust mine too! Good thing i dont have to pull a kb off!
Aliate X
602
Rockland NY
Feb 7, 2007
  • Feb 7, 2007
Yup my TFS rockers make some noise too sounds like a sewing machine lol.
Modular2v
3,222
23
99
oklahoma
Feb 7, 2007
  • Feb 7, 2007
wow...thats exactly how i would describe it!
gtxracing
49
  • Feb 7, 2007
Just curious, what size the GT40p and GT40 rockers are?
D
Daggar
3,902
  • Feb 7, 2007
What ratio, do you mean? I believe that they're all 1.6
You have to go aftermarket (even FMS) for a roller block rocker in a ratio other than that.
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Feb 7, 2007
Daggar said:
I'm running the CRANE RRs and mine are a bit noisier than I'd like as well.
Aliate X said:
Yup my CRANE rockers make some noise too sounds like a sewing machine lol.
Fixt
Trickflow buys thier roller rockers from Crane and has them anodized a different color. Just in case you 2 fine gentleman didnt know that
putnam88
102
tavares
Feb 7, 2007
#10
  • Feb 7, 2007
  • #10
actually the ticking comes from when the valve just touches the top of the piston and it is a very light touch dose not damage unless ratio is to large. the ticking is good and maximizes hp if it gets to loud kinda like a thud ur doing damage if it dont make it at all ur losing power
Jason 302
685
71
68
Newark, Ohio
Feb 7, 2007
#11
  • Feb 7, 2007
  • #11
I hope you're not being serious...
F
FoxNotch
#12
  • Feb 7, 2007
  • #12
I have the trick flows as well. When the engine cold it sounds like a sewing machine but once she warms up a bit it quiets down a tad.
But yea Ive just gotten used to it, it's not that bad.
putnam88
102
tavares
Feb 7, 2007
#13
  • Feb 7, 2007
  • #13
DUH!!!
Mustang78
486
Aberdeen, WA
Feb 8, 2007
#14
  • Feb 8, 2007
  • #14
the valve should NEVER hit the piston..my buddy built a 496 chevy BB and his valves barely hit the pistons, without his knowledge..which led to a broken intake valve taking out chunks of cylinder wall, bending a rod, and getting lodged sideways in his new 2,000.00 aluminum heads..also the piston gets closer to the valve at higher RPM's..so it will get worse if they touch..(which they shouldent)
~Mark~
Jason 302
685
71
68
Newark, Ohio
Feb 8, 2007
#15
  • Feb 8, 2007
  • #15
putnam88 said:
DUH!!!
LOL thank god!
wild86stang
115
Milan, OH
Feb 8, 2007
#16
  • Feb 8, 2007
  • #16
+1 for the TF's being noisy
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Feb 9, 2007
#17
  • Feb 9, 2007
  • #17
sorry I didnt get back to ya guys, yeah I dont think the valves should touch the pistons LOL, but I got all the little bugs worked out, and man does it haul serious!! my t5 is whining real bad now LOL, but thanks for all the help!!
Josh
304billet
315
#18
  • Feb 10, 2007
  • #18
My RR were noisy as hell also. using Track heat 205 heads with Harland sharp 1.6 stud mount RR specially made for TW heads with offset intake RR's. preload was set at 1/4 turn. went to 1/2 turn preload and quited them down a whole lot. much nicer to drive.
also aluminum valve cobers also contribute to RR noise. Try sheet metal VC's they r quieter.
gnx547
283
#19
  • May 14, 2007
  • #19
What are some good sheet metal valve covers to go with?
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
What in gods green earth happend to my N/A 2.3?
  • Piranahbite
  • Mar 24, 2024
  • 2.3L (N/A & Turbo) Tech
2K
2.3L (N/A & Turbo) Tech Jun 1, 2024
Piranahbite
