Zero, the ideal way to do it is to tune the MAF function tables in the EEC instead of useing a cal'd meter. For those that don't know, "calibrated" meters compensate for larger injectors by tricking the EEC into thinking less air is actually coming into the car than really is. The EEC then uses a smaller pulsewidth than it normally would for the actual amount of air coming into the engine, but since there is an injector on the car that is larger than stock and flows more, this shorter pulse width actually flows more fuel than it did before. Some of the problems with the 94-95 processors is that they use LOAD for a lot more tables in the EEC than the A9L family of processors did. That being said, load is determined in our cars via the MAF, so when we go tricking the output voltage of the meter we end up messing with the LOAD as well inadvertently. I will say this, I had my MAF tranfer function tables re-done to read true voltage from the MAF so I wasn't relying on this "tricked voltage" this should have yielded a better running car and theoretically more power... it did neither. The car lost 1HP and gained 2ftlbs of torque, but it would stall all the time and ate fuel like it was candy, so I went back to the calibrated meter and factory EEC tables.
