Why is my car acting cold natured?
grrman13b
My 91' LX 5.0 has starded acting cold natured for about a month now. It runs fine once I get going, but acts cold natured when I start it and let it run for a few minutes. I have to keep it running with my foot on the gas for a minute or two or it will die. I thought only carbaurated motors only did this, what should I look at first to help fix this problem? :shrug:
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/article...c-iv_codes.html
IF your car is an 88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart .
my car does the same thing, i tried 3 iac in the past month, cleaned out tb and air filter. I havent tried tps yet. Do you have a Mech. water guage? I have one and tapped it into the stock location. It might be causing it b/c comp is no longer getting readings.
I cleaned my IAC just because I had nothing else to do, and ever since then my car doesn't run right. If it sits for 7+ hour, when I start it up it will idle at 1.5k for about 30 seconds. I've even put a new IAC on it, and it didn't change anything. So I wouldn't advise to clean the IAC.
Cleaning IAC fixed my idle issues.
I HAVE however had similar issues with it having an odd (floating) idle at startup after the car has sat for a little while. It all corrects itself after a minute or so and runs VERY nice and smooth.
