Why so rich?
  • Thread starter Thread starter 93RiceKillinGT
  • Start date Start date Jun 19, 2005
9
93RiceKillinGT
60
somers Ct
Jun 19, 2005
  • Jun 19, 2005
Im still fine tuneing my freshly rebuilt 306, you'll see all the specs in my sig. The new engine has at least 115 miles on it I just changed the oil for the 2nd time yesterday to help fulsh out the small metal particles and such and the oil smelt a little like gas! The oil was only about 115 miles old and it also had a black tint to it as if the oil was prematurely getting old. Today I pulled a spark plug out and found it to be black, which indicates a rich running condition. Now I backed of on the fuel pressure to about 34 PSI from the 40 PSI I had before and the exhaust still smells very rich. The car runs really good though, tons of torque and good top end power. The highest i Have brought it up to was 4000 RPM and she still pulled harder and harder.
My breaking in of the engine thus far involves stop and go driveing, varying the RPM's and some hard acceleration every now and then up to 4,000 RPM. The car idles really well and accerates very well also. But while cruseing at a stable RPM like lets say 1800 or 2200 the check engine light likes to flash on, stay on and shut of every now and then. Could this fuel in the oil and rich running condition be cause by, blow by and the piston rings still breaking in? Also Should I have the TPS Sensor Voltage set at 1.00 becuase right now im running an Edlebrcok 70 MM Throttle body and the instructions said voltage readings between .800-1.0 is good? Any sugestions would be awsome!
Thanks
9
93RiceKillinGT
60
somers Ct
Jun 19, 2005
  • Jun 19, 2005
bump
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
