Why would anyone need hardened pushrods?
Pokageek
2,767
MA, USA
Does it make a set up like mine safer to run hard or is it more for really high HP or supercharging or something?? Just curious..y'all know my set up..I am getting a 306 with crane 2031, flat top pistons (highest compression possible on pump with the right heads), stock heads (for now), decked and honed(whatever that means). Thx.
A couple of good reasons.
If you run guide plates you will need hardened pushrods. Otherwise when the guide plates come into contact with the pushrod they will begin to wear and as the pushrod is 'eroded' by the guide plate contact, the ejected metal from the pushrod will flow into your oil and potentially cause excessive wear on your bearings. Additionally, as the pushrods wear, they will eventually fail/bend.
I agree about the "wear" and erosion...but are there REALLY going to be metal pieces flowing around in there? Erosion is a long-term process. Im assuming we are all chaning the oil regularly. Hardened ones should def. be used, but is the metal in the oil more just 'theoretical'?
RC
RC
RC
I have not had the probs you talk about but I have seen threads where peeps did not know to use hardeded pr's when needed and they said they had metal shavings everywhere.
Later
Grady
My brother (dodgestang) and I built a 408 stroker cleveland. Langhorne speed shop gave us non hardened pushrods by accident. It was carnage. Metal everywhere. Don't mess around here. Its not worth it.
jer
