Why
  • Thread starter Thread starter GREG91GT
  • Start date Start date May 13, 2005
GREG91GT
207
MISSOURI
May 13, 2005
  • May 13, 2005
Why am i hitting the rev limiter,i have a c-4 tranny,with 4.10s,and i hit the rev limiter in 3rd before i reach the end of the track in the 1/8th mile my time slip is 60ft 1.57 1/8th mile ET is7.3 and mph is 85.56 i think thats a weird mph for that time anyone no whats going on?
NOSNotch
577
South Jersey
May 13, 2005
  • May 13, 2005
I dont think the 4.10s are really helpin ya out with the c4, what are you shifting at and do you still have the stock limiter?
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 13, 2005
  • May 13, 2005
Only way I could see you hitting the rev limiterin that situation is if you're spinning your tires or you're not really in third.
GREG91GT
207
MISSOURI
May 13, 2005
  • May 13, 2005
I am shifting at 6250 thats the stock limiter, the only other reason i think it is happening is that my converter is a little to loose
GREG91GT
207
MISSOURI
May 13, 2005
  • May 13, 2005
any other ideas
rd
3,316
63
109
Ocean Springs MS
May 13, 2005
  • May 13, 2005
Thats a pretty good time for the eigth mile. I'd be happy with it....
I have a C4, with 4.10's that runs 8.2@80 or so in the eigth on the motor, and 7.80@90 even on spray.
I ran some numbers and figured that I could use 4.56 gears in the 1/8th, and trap a max of 100, so I have room left to improve.
If it is really hitting the limiter, the converter may be too loose, or the trans is slipping in high, or you have tire spin. The converter is the most likely item. It seems to be working well in first and second thought.
GREG91GT
207
MISSOURI
May 13, 2005
  • May 13, 2005
yea the car runs very well i am very happy with it, i think it would run allot better if i didint rev out,do you no the proper way to ajust the 2nd and 3rd band ajuster nut,i think i do but i am not sure.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
May 13, 2005
  • May 13, 2005
I did some quick calculations myself...
Based on running a C4/26" tire/4.10's/4% converter slip (?)
3rd Gear at 6250RPM would be about 110MPH.
A little creative math tells me that your converter would have tobe slipping about 20% in order to hit the rev limiter at about 95MPH in 3rd gear.
...just a little more info to consider.
GREG91GT
207
MISSOURI
May 13, 2005
  • May 13, 2005
89mustanggx thanks for the info,my converter is a custom converter made just for my car and motor and its set up for the 8th mile the car will foot brake at about 3800 rpm
jadedinpa
1,094
lancaster, pa
May 13, 2005
#10
  • May 13, 2005
  • #10
what size tires are you running?
GREG91GT
207
MISSOURI
May 13, 2005
#11
  • May 13, 2005
  • #11
28/9/15 hoosiers
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
May 13, 2005
#12
  • May 13, 2005
  • #12
Like 89 said gearing/rpm tire size & speed of the car does 6250 equal... unless you are loosing alot of RPM somewhere. Plus your running a 2 inch taller tire than he to into acct for.
Something seems wrong to me.
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
May 13, 2005
#13
  • May 13, 2005
  • #13
FWIW
4.10's + 28" tire+ 1.00 ratio third gear + 6250 RPM = 128mph (assuming 100% lock & no slip)
Where ever your slipping here it at about a 33-34% rate.
GREG91GT
207
MISSOURI
May 13, 2005
#14
  • May 13, 2005
  • #14
do you think my converter was made to do that like i said it was made just for my setup it cost me about 850 dollors,it hits the rev limiter about15yrds before the finish line when i ordered this converter they wanted my engine size,gear ratio,cars weight,aproxment horse power,tire size,nitrous or sc,cam specs,what heads,valve size,and allot more they wanted everything.
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
Aod to t5 swap will it live?
  • 87slow.0
  • Nov 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2024
87slow.0
  • dan50
  • Jul 18, 2026
dan50
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
