wideband
Hef5.0weisen
Mar 5, 2004
574
NorthWest Florida
Anyone running a wideband......where did you install the sensor? Looking for an approximate location, or an opinion of the ideal location..... (left tube, 8 inches from the header joint, 3 o'clock position...know what I mean)
This is going to go into an h-pipe off of shorty headers.....
About 16" from the collector and while 9-3 o'clock is fine between 10-2 is better. Rationale. The WB will not take the heat that an NB will and if it's placed where condensation will collect the element will likely fail. Driver's side is preferred as #8 cylinder due to air flow tends to run leaner than the others. Tuning on the side running lean is precautionary.
