Wierd Cooling Issues- never seen this before- help?
210 isn't that hot, but the O.E. radiators weren't good pieces to start with. Neither were the fans. Water absorbs heat better due to the surface tension difference. Water-Wetter thins this and thus helps this. But it also will find leakey joints faster too.
All right, I flushed the radiator again, added 50/50 mix (with bottled water), water wetter- and went to a higher pressure cap- (running 14lbs now)
Here are the constants- things I did not change
Car has a shroud, fan half way in
180 thermostat
timing set at 12 degrees
long tube headers with MagnaFlow mufflers-
3 row radiator (found receipt)
The result is a 10 degree drop in temperature-
I can live with 200- Id perfer 180-190 but I can live with 200-
Thanks for your help guys- this place rocks-
