Drivetrain Wierd Grinding Noises
  • Thread starter Thread starter Wonderbread750
  • Start date Start date Sep 12, 2014
W
Wonderbread750
70
  • Sep 12, 2014
I just replaced the clutch and did everything better then how the books say, like no joke, but now, when its idling out of gear it grinds bad!! And it makes shiver in curiosity why, i take of and give it gas and the noise goes away until i let off the gas, what the helll is that noise?! Maybe a nut or bolt somehow got in the exhaust? Clutch slipping?! Please help my only 2 solid ideas would be a harmonic balancer or an nut inside the exhaust, has anyone dealt and solved this?
stykthyn
5,232
2,652
223
gainesville
Sep 13, 2014
  • Sep 13, 2014
What clutch did you use?
Micheal Nadeau
258
32
49
Savannah, GA
Sep 14, 2014
  • Sep 14, 2014
does the noise go away when you press the clutch pedal in?
W
Wonderbread750
70
  • Sep 14, 2014
No it goes away after 1300 rpm and driving, i tried out the exedy stage one kit it just sounds like a bad harmonic balancer grind but i dont think thats it
stykthyn
5,232
2,652
223
gainesville
Sep 14, 2014
  • Sep 14, 2014
Really sounds like be clutch/ flywheel was tightened out of balance.
W
Wonderbread750
70
  • Sep 14, 2014
It was perfect when i first ran it a few miles, but i did do a few burnouts then coming up from morongo a day later it started kicking in
Micheal Nadeau
258
32
49
Savannah, GA
Sep 14, 2014
  • Sep 14, 2014
I can't say that I have ever heard a harmonic balancer "grind". Are you able to get under it while it's idling to pinpoint where it is coming form?
W
Wonderbread750
70
  • Sep 14, 2014
They grind when the polyurethane piece goes out, but it soujds just like that but the balancer would wobble worse then a penguin, but it doesnt, and if my flywheel was tightened wrong, why does it grind during idle and not when rpms rise?
Micheal Nadeau
258
32
49
Savannah, GA
Sep 14, 2014
  • Sep 14, 2014
Throw out bearing
W
Wonderbread750
70
#10
  • Sep 14, 2014
  • #10
It was a brand new installed, greased down the shaft and bearing when installed
Micheal Nadeau
258
32
49
Savannah, GA
Sep 14, 2014
#11
  • Sep 14, 2014
  • #11
Did you put the bearing above or below the springs on the fork?
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
J
  • JRC99
  • Apr 19, 2025
JRC99
J
C
Progress Thread 2004 Comp Orange GT
  • ctandc
  • Jun 26, 2023
  • 2 3 4
6K
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 1:36 PM
ctandc
C
Random noise help
  • zookeeper
  • Mar 31, 2021
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 5, 2021
zookeeper
Constant chirping noise from clutch/trans!!!
  • steezy2110
  • Nov 27, 2020
3K
SN95 4.6L Mustang Tech Mar 30, 2021
GT4Lyfe
G
