Wierd noise! Any advice????
rio99Cobra
Hello,
I have a 99 Cobra and I have recently noticed what sounds like a grinding noise when I hold the RPM's steady, accelerate very slowly, or back off the throttle (as if you were holding 3500 RPM's and let off the gas peddle, slowly accelerated, etc). It occurs at all RPM's until the car is warm, then disappears. The car has a BBk intake, 62MM throttle body, x-pipe (catless), magnaflows, B&M short throw, drive-line specialties complete rear-end build with 3:73's. I want to let everyone who may read know what is done to the car in case it makes a difference. I consider myself mechanically inclined, but this is my first 4 valve 4.6. My first guess was throw out/pilot bearing? But it sounds like it is coming from the motor. The noise is present when the clutch is engaged or disengaged. The only thing that affects the noise is the car warming up. It had sat for awhile as a weekend driver here in Michigan. I thought the throw out bearing may have siezed some how or something wierd, I don't know, thats why I'm here. Car has 44,000 miles on it. Thanks for any help you may have to offer.
Hmmm, I'm not sure what it could be... but does it make the sound if you run the engine in neutral? I really don't have any ideas without hearing it myself. Perhaps a local shop could figure it out? Hope it turns out ok!
I agree, I think it is the bearing myself. I spent some time looking at over the weekend and listening. When I put pressure on the peddle it starts to whine. The clutch feels great, did some nice burn outs after diagnosing it! I think I pull it out this spring and replace the throw out and pilot bearings and put a new clutch in it anyway. I really appreciate the help guys! Thanks!
