I just converted my car to mass air using an 80mm Pro-m MAF, A9P, and the FMS conversion harness that comes with those expensive conversion kits. Well I checked the TPS voltage and I cant get it any higher than .85v at idle and when its that high it idles at 1500rpms, so I have it at .60v right now and it idles around 750rpms. When I start it the idle will jump to 2000rpms, then step down to 1500rpms then die. It wont die if I goose the throttle alittle, if I do that it will idle down to 750rpms and idle kind of rough. I pulled the codes and I got: 24, and 34. With the speed density computer I didn't get any codes.
Im alittle stumped so any suggestions are dreatly appriciated.
