Wierd Timing Question
rowdie- stang
172
augusta ga
I just installed a dss 347 with a msd distributor My question is it idles very high (2500 rpm) when I set the timing at 10 btdc, when I adjust it to 10 atdc it idles fine it also overheats very quickly. oculd this be a vacuum leak around the intake or something.....I have to pull the top end apart anyways to retorq everything. Has anyone had a problem of this sort.... :shrug:
i like the vac leak idea. also make sure your balancer has not slipped at all (giving you false reference points for timing it).
good luck.
Get a can of brake cleaner or gum cutter and start spraying around your intake and vaccume hoses. If you have a vaccume leak, it'll suck in the stuff and the rev's will increase briefly.
A high TPS setting can cause a fast idle as well, so check it's voltage.
#1 reaches TDC at two different points in the 4 stroke cycle. One is at the top of the compression stroke, and this is the TDC that you are looking for when setting ignition timing.
The other is at the top of the exhaust stroke. If your sparking happens here, that's when your dizzy is 180* out.
However, she isn't going to run like this, so if it runs at all, you don't have this problem.
If you're using the Ford Idle Air adjustment plate between the IAC and the throttlebody, the two screws (2.5mm allen screws) need to be screwed all the in to be closed. If they are all the way out it's wide open and you're letting more air through at idle.
