Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Thread starter Thread starter Warhorse85
  • Start date Start date Aug 16, 2025
W
Warhorse85
66
17
18
Aug 16, 2025
  • Aug 16, 2025
Hello everyone, I'm having trouble figuring out why my wifes 1993 LX 5.0 dies while idling after replacing some ignition parts. The parts I have replaced are the MAF, TFI module and ignition coil. EGR was replaced last year. Car starts and runs great but after idling for a bit it surges for a couple of seconds then goes back to idling normal then about 5-10 seconds later it just dies as if someone turned the ignition key off. It will instantly restart and idle with no issue for a few minutes and do the exact same thing. I did notice that there is a loud buzzing noise coming from the EGR area while it's idling. Any help would be greatly appreciated.
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,205
1,440
133
San Diego, CA
Aug 16, 2025
  • Aug 16, 2025
What TFI module did you use and did you use thermal grease in the mating surface?
W
Warhorse85
66
17
18
Aug 16, 2025
  • Aug 16, 2025
Motorcraft and no I did not use thermal grease
KRUISR
1,822
929
143
Aug 16, 2025
  • Aug 16, 2025
Fuel pressure regulator sticking or not cycling right?
W
Warhorse85
66
17
18
Aug 16, 2025
  • Aug 16, 2025
No clue, no idea how to check. Definitely not a fuel issue
gkomo
Aug 2, 2024
2,205
1,440
133
San Diego, CA
Aug 16, 2025
  • Aug 16, 2025
TFI could be getting too hot or something and causing issues… I believe they need thermal grease on the mating surface.
slow84lx
clean it good before insertion
Jul 3, 2005
372
180
63
Dallas, TX
Aug 17, 2025
  • Aug 17, 2025
Just curious, why did you change these parts? Were you trying to resolve a problem? Do you still have the parts that you took off?
My first thought is to put the TFI that you took off back on and see if that solves the current problem.
Reactions: 2000xp8
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,472
2,903
173
Florida
Aug 17, 2025
  • Aug 17, 2025
OH man, I bet you are on the $hit list at home
AeroCoupe
5,959
4,073
183
Claremore, OK
Aug 17, 2025
  • Aug 17, 2025
@Noobz347 - can you merge this thread with the one over in the Fox 5.0 tech forum?
Admin Dude
Jan 4, 1985
43,178
21,344
234
Box behind Walmart
Aug 17, 2025
#10
  • Aug 17, 2025
  • #10
I'll close this one since the merge will make a mess.
W
Thread '1993 LX 5.0 dies after ignition parts replacement'
Aug 16, 2025
Hello everyone, I'm having trouble figuring out why my wifes 1993 LX 5.0 dies while idling after replacing some ignition parts. The parts I have replaced are the MAF, TFI module and ignition coil. EGR was replaced last year. Car starts and runs great but after idling for a bit it surges for a couple of seconds then goes back to idling normal then about 5-10 seconds later it just dies as if someone turned the ignition key off. It will instantly restart and idle with no issue for a few minutes and do the exact same thing. I did notice that there is a loud buzzing noise coming from the EGR...
  • Warhorse85
W
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
3K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2026
Ryu
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
