Will 03/04 Cobra Bilstein/Cobra shocks/struts fit a GT?
now when you say "valved for irs" what do you mean?
I think they are stiffer than standard solid axle HD's to compensate for the totally different rear suspension setup, & to match 03/04 Cobra rear spring rates? For example, 03/04 Cobra stock rear springs are 600lb/inch spring rate, as opposed to stock gt rear springs which have a rate of 200 lb/inch. The 03/04 Cobra bilsteins are valved differently, or essentially stiffer to match up with that spring rate...
They will physically bolt in to your car, but will be VERY, VERY stiff to the point to where it will be unbearable.
Check out this link to better understand what shock valving means....
http://www.hyperracing.com/docs/Shocks.pdf
