i've got mark vii rotors up front on my coupe and before i buy them i was wondering if anyone knew for sure that they would bolt up to the brake setup? thanks
Which of the ford rims will bolt up to the Mark 7 rotors without problems.
theyll bolt up, but you wont be able to run with the centercap.
94-96 16" waffle stars
94-95 17" GT wheels
'95 Cobra R's
94-97 Cobra wheels
All you would have to do it pound the grease cap in a little bit. They'll fit fine.
Usually a combo of pounding the grease cap PLUS a small spacer is needed to make them fit.
I don't like the idea of spacers however. If you need a spacer to make a wheel fit, then the wheel DOES NOT fit in my view.
A lot of people recommend extreme things like grinding the spindle as well but that's eveb worse than a spacer. Some people buy cheap spacers that fit loosely, don't upgrade to hardened studs and don't torque the wheel properly and it's just asking for the wheel to snap off under high load.
My point is to do things right
will the center caps for the wheels fit without the bearing greese caps on.
If so there has to be a way to work around the greese cap.
If anyone can tell me about the fitment of the center caps with the greese caps removed, And they say the centercaps fit then I will go this route and will find a way to make them work.
With the wheel bolted up and the centercaps on is the greese-cap really needed on a rim like a 03cobra. Where the bearing will be inclosed in its own space from the elements.
94-95 17" GT wheels
'95 Cobra R's
94-97 Cobra wheels
I think the Standard 99-01 GT Wheels fit too as they have the large covered center like the Waffle Wheels.
You are right, the 16" 99-00 GT wheels will fit as well.
They are the same as V6 wheels, and i beleive all 16" V6 wheels will fit as well.
