will 3 core rad fit ???
91whiteponygt
61
will a two or three core rad for an automatic fit with stock fan and overflow tank or will i have to custom fit??? any suggestion on good budget buy???? how easy does stock fan clutch assembly come off?
I just put in a stock replacement 3-row and it fits great. The fan shroud and overflow tank bolted up fine, but I may have had to leave off one of the fan shroud mounting bolts, I don't recall for sure.
Also one of the clamps that bolts down over the top of the tank doesn't sit down quite as low as it did on the stock radiator, and runs into the hood insulation a little bit, so I have to shut the hood a little harder.
But overall, yeah, a stock replacement 3-row will fit great.
Jeff
Jeff
:nice:
Good to hear you got it in there.
Double check that the rubber insulator is properly seated. It should be sitting like stock.
I'll take another look and make sure everything is seated correctly. It was a couple months ago I got the radiator in, but if I remember, the "width" of the side tanks (distance front to back as it sits in the car) is a little greater than the stock radiator, which stopped the rubber insulator from fitting down over it quite right. It's pretty close though. I'll take a closer look when I'm under the hood this weekend.
Thanks.
Jeff
My OEM-style 3-core dropped right in, just had to trim the top and bottom rubber insulators a tad to make it sit right, and I had to bend the brackets a little to make it clamp things down into place safely - didn't want my radiator bouncing around in there.
