I've heard of some mustang guys using the injectors out of an LS1 for 24lb injectors i think their flow rate is 26lb not sure exactly but it's measured alittle different so it's actually around 21 or 24lb on a ford, Something along those lines.
Got to thinking if someone wanted some cheap 36lb injectors for a boosted motor couldn't you use some 36lb injectors from a GTP? They are the same impedance an the connector's look the same. Maybe i'm wrong though just an idea since you can get them pretty cheap from grand prix forums.
