Will a 66 toploader work in a 67
  • Thread starter Thread starter BDT 1967
  • Start date Start date Feb 15, 2006
BDT 1967
91
Wichita KS
Feb 15, 2006
  • Feb 15, 2006
I just found a toploader 4 speed out of a 66 289. I would like to know if it will work in my 67 and bolt up with out a problem. HEHBW 015157. is the id numbers.
BDT 1967
91
Wichita KS
Feb 15, 2006
  • Feb 15, 2006
alright i just read in my mustang monthly that it will work this is a good thing. What i dont understand is, if a close or wide ratio is better for a small block.
fasttback
471
Northern CA
Feb 15, 2006
  • Feb 15, 2006
Affirmative on the toploader switch. I am in the middle of a '67 to '66 toploader switch (just different clutch pedals, z-bar, etc).
As for the wide vs close ratio - you can use either. Close ratio give you a first gear that is closer (ratio) to the second gear (the actually size has been posted on this forum somewhere).
Make sure you get a toploader for a small block vs big block, if its going in a 289.
D
D.Hearne
11,730
south louisiana
Feb 15, 2006
  • Feb 15, 2006
As to which is better ( close vs wide) Close works better with rear gears in the 3.70-410 range. Wide is better with 2.75-3.50's. Close ratio has a 2.32 1st gear, wide has a 2.78 1st.
wild70stang
317
  • Feb 15, 2006
if your like me and you dont understand gears yet wide=street close=strip.
BDT 1967
91
Wichita KS
Feb 15, 2006
  • Feb 15, 2006
Thanks, That is just the info that I needed, This is a show car and dispite my friends best efforts to run this car to its potential, It will never see the track.
D
D.Hearne
11,730
south louisiana
Feb 15, 2006
  • Feb 15, 2006
You've got it wrong still Wide works good on street and strip. But also depends on the rear gears. Close is more of a "road race" transmission.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Feb 15, 2006
  • Feb 15, 2006
Yes, it will be fine.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
