will a 99 8.8 fit under an 88
rjnxr7
looked around havent seen an answer really ,but just wondering will the rear end out of an 99 gt fit under an 88?I AM THINKING FROM WHAT I HAVE READ that it will be 1/2 an inch wider on both sides is that it though?
Nearly 1.25" wider EACH side.
The housing on the 99=04 axle is wider than the 86-98 axles. The LCA mount holes are also a different size than the 86-98 axle. Also you'll need to fab up a brake line
It can work, but you gotta pay attention to wheel offset and BS
