Will a t-5 last
85ragtop
BTW, I like dudes.
475
123
NC
I have almost all of the 351 put togather. My AOD was in bad shape when I parked the car. I looked at getting a new one but the cost is not worth it. So I was wondering if I should get a reworked t-5 or some other 5 speed. I just want a trans that will last.
A T5 won't even hold up behind a stock 5.0 so forget it behind a 351. You should go with either a Tremec (heavy, no options) or a G Force (lightweight and no modifications needed to install). I know the T5 is cheap and the other two aren't but you'll have more headaches once third gear starts breaking again and again.
It all depends on how much and how hard you drive your car. My T5 lasted me 6,000 miles after I supercharged my car..while my friend has gone through 3 of them in 8 months on his stock 5.0..
Tremec all the way, if your gonna do something do it right the first time and save yourself the trouble and hassle, because if you go with a T-5 you'll be going through them like skittles.
Yea, I had 3 AOD's in two years. The last time I had it redone to handle 350hp. It lasted six months. I will see if I can find one around here. Oh what is the difference in a 500 and the 600?
If you have the money, do it right the first time. That way you won't be swapping trannies for a while. You'll thank yourself later.
With that said, it basically comes down to how much power and how hard you are gonna be on it. Some people can get away with things others can't. The old addage "what works for some doesn't work for others". I have been running the stock t-5 that has never been touched (other than fluid change) and it has over 180,000 on it and for the last year it has had the 347 and nitrous thrown to it.
I'd definitely say do it right the first time. I converted to a T-5 from AOD a few months ago and I only had 500 miles on the T-5, (Which supposedly was upgraded to handle 350 hp) before I blew it up behind a 300 hp bolt on motor. Can anyone guess what broke? that's right 3rd gear. I shifted into 3rd at 5K and BOOM! I finally got it all pulled apart and all the teeth are missing from 3rd and the counter gear and the teeth chewed up all the synchros. I just finished installing my TREMEC TKO 600 on Friday and that thing is bad a$$. Very queit, very smooth, and very precise.
Yeah unless you get a serious aftermarket kit for your T5 it won't hold. Save yourself the hastle and upgrade to a TKO 500 or 600. The 500 can hold 600 ft lbs of torque with the 26 spline input shaft. The 500 is geared really closely to the stock T5 gearing so take that into consideration. If you are putting down some power you might want to opt for the 600 right out because first and second won't be so short. Typical things that kill the T5 are good traction and hard shifts... which looks like what you are going to be doing. Stock 5.0s break T5s so take that into consideration.
Kevin
I started anouther thread about putting a blower on my 351, but it looks like it is going to cost too much. So I will do what I do best, 250 shot of nos.
my car has had 6 t-5 put in behind my 351w. of course all these tranny's were junk yard specials. i currentally have a rebuilt world class t-5. it has held up to 2 summers driving so far. i am not easy on my car. it seems to be lasting. if you want reliability get a tko 600
