Will a t-5 last
  • Thread starter Thread starter 85ragtop
  • Start date Start date Jul 12, 2006
First Prev 2 of 2
vristang
4,933
101
124
Seattle
Jul 12, 2006
#21
  • Jul 12, 2006
  • #21
I am still using the factory T5 in my GT.
At 185k miles I put in a 351w.
AT 190k miles I built the 408w.
I have about 20k miles on the 408w and the trans is just starting to show signs of wear (it resists going into gear sometimes).
That is my experience,
jason
85ragtop
BTW, I like dudes.
475
123
NC
Jul 12, 2006
#22
  • Jul 12, 2006
  • #22
Well I can get a t-5 from my buddy for $300. I may run that until I can get a 600.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Jul 12, 2006
#23
  • Jul 12, 2006
  • #23
i love the ole t5
W
wgpaintballer
49
#24
  • Jul 12, 2006
  • #24
t5
Both options will be expensive. Your best bet is either a TKO or a builit AOD. For track use u kno u should go with a AOD or a C4.. but thats up to u. I would go with the TKO if i had the $
85ragtop
BTW, I like dudes.
475
123
NC
Jul 12, 2006
#25
  • Jul 12, 2006
  • #25
It will only be at the track once month or so.
Sicarius428
2,085
Jul 12, 2006
#26
  • Jul 12, 2006
  • #26
The T5 may or may not hold you over. Mine broke within 1000 miles of my H/I/C and supporting mods. I was rough on it but I don't have slicks. Mine stopped going into gear from a dead stop unless I held the clutch in the whole light. It really is luck. Some people's T5s last longer than others...
Kevin
85ragtop
BTW, I like dudes.
475
123
NC
Jul 12, 2006
#27
  • Jul 12, 2006
  • #27
I dont think it will be in there all that long.
JChalfan
551
Bellevue, WA
Jul 12, 2006
#28
  • Jul 12, 2006
  • #28
Like most people said, chances are the T5 will not last in the long run. That being said...
If you can get a good deal on a whole T5 setup, it would at least get you on the road. Then when you decided to upgrade to a better 5-speed, you would have the clutch pedal and everything ready to go. I don't know if the T5 uses the same bellhousing or shifter as the better 5-speeds.
To echo what people have already said, I have heard of T5's lasting a long time with a lot of abuse, but more often I hear of people breaking them with a pretty much stock 5.0. Traction will kill it. I went through at least 1 T5 in my last 5.0, which was about a 300hp bolt on motor, and it never saw slicks.
Go for the T5 now if you want, just know there's a very good chance you will need to upgrade not too far down the road.
Jeff
foxbody88stang
21
COLUMBUS,OH
Jul 12, 2006
#29
  • Jul 12, 2006
  • #29
ART CARR C4 1600$ LIFETIME WARRENTY HARD TO BEAT FOR THE STRENTH AND MONEY
Sicarius428
2,085
Jul 12, 2006
#30
  • Jul 12, 2006
  • #30
The TKOs use a different bellhousing, yoke, crossmember(stock one can be modified) and clutch disk depending if you get a TKO500/3550(10 spline same as T5) or the 600(26 spline). You can use the same pressure plate and flywheel. If the T5 gets you on the road sooner, definately get it driving and work the kinks out of it. Just keep in the back of your mind that if you start to abuse it, it may likely break. The TKO comes with a Hurst shifter. It is a bit stiff but I only have 60 or so miles on mine so far. Still an improvement over the stock T5 shifter.
Kevin
85ragtop
BTW, I like dudes.
475
123
NC
Jul 13, 2006
#31
  • Jul 13, 2006
  • #31
Thanks, I will get the t-5 for now.
eagleautosports
139
Mebane NC
Jul 13, 2006
#32
  • Jul 13, 2006
  • #32
Hey, did you get that mail I sent you about Carolina Mustang? They have a Tremec sitting on the showroom floor right now. They're down in Cary, about 10 miles west of Raleigh. Check them out.
D
Deleted member 87397
Jul 13, 2006
#33
  • Jul 13, 2006
  • #33
Well if you can score one for 300 then use it till it blows up, but if you were going to pay 600-900 for a rebuilt one then I'd say TKO or G-Force
85ragtop
BTW, I like dudes.
475
123
NC
Jul 13, 2006
#34
  • Jul 13, 2006
  • #34
Hey thanks man. I will check them out when I get a chance. I get most of my parts from Summit, so I dont know any of the shops around.
eagleautosports
139
Mebane NC
Jul 14, 2006
#35
  • Jul 14, 2006
  • #35
They know me by name now, I've been there so much. If you want, the number is 919-467-2900 and the guy to talk to is Gary. It isn't too much of a ride from me, about 45 minutes to an hour. I'd rather go there and get it today then wait 2 days for UPS.
First Prev 2 of 2
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
  • brandyn200
  • Jun 20, 2026
AeroCoupe
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
