will my rims fit?
i have an 00gt. im about to get new rims. i want to get 9" on the front and 10/10.5" on the back. will i have a problem with the backs fitting. will deepdish rims rub in the back if i decided to go with them. also what would be the best tires to put on the back.
Thanks
No, you shouldn't have any problems with them rubbing. I have 10.5" with no problems at all and running sumos HRTZ. Only reason for those was because they were cheap. :D . Not a bad tire though.
American Racing Torq Thrust II, spec for the SN-95 ---> http://www.americanracing.com/wheel...le=505&desc=2-piece alloy, polished&section=V
Front - part # 505-79567 Size: 17x9.5 Offset: 28mm Backside: 6 3/8"
Rear - part # 505-71167 Size: 17x11 Offset: 27mm Backside: 7"
