Will the stock computer run this combo?
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Just like the title says, will my stock A9L computer run this combo ok with no chip?
5.0 5spd:
GT40 intake
65mm edelbrock TB
75mm MAF
EGR coolant lines plugged due to no bung in intake
Air Temp sensor moved to intake rubber duct due to no bung in intake
no smog pump
full o/r exhaust
130 amp alt.
155 lph pump
E303 camshaft
5.0 5spd:
GT40 intake
65mm edelbrock TB
75mm MAF
no smog pump
full o/r exhaust
130 amp alt.
155 lph pump
E303 camshaft
I am using the stock computer and it runs GREAT!
just real quick, how much fuel pressure? if your MAF compatible with your injectors? does it run hot at all?
idealistically, we should all run 42psi, no more...but since the stock puter is very set in it's ways for fuel timing, it's a good way to offset the stock maps.
also...i'd bump the timing up a couple degrees...just me though.
problem is fixed! I broke down and went and bought a 20 dollar code reader, and for next to nothing fixed the problem. Turned out the TPS voltage was way too high and the EGR valve didnt have any vacuum! Thanks for the help guys she is running like a champ now!
