At the junkyard they hauled in a V6 coupe w/ a good set of wheel/tires...its the 16"....and i doubt they will but would they work on my '66?
TireSmoknWindsr said:At the junkyard they hauled in a V6 coupe w/ a good set of wheel/tires...its the 16"....and i doubt they will but would they work on my '66?
TireSmoknWindsr said:I hadn't saw those for the 16" wheels i dont think...i thought they were all for like the GT wheels. maybe both though...my concern was whether that would work on my front suspension b/c i dont have a negative wedge kit or anything and they are generally needed w/ 16s...or is that with disc brakes? because i have drum all around.
dodgestang said:The problem with 16s is when the have the proper backspacing for an early mustang, if you a arm is in the stock location, many people have reported the rim hits the upper ball joint.....for those that have done the shelby a arm drop, its hit or miss...but most seem to clear ok.
67efivert said:could someone explain how the negative wedge helps out the ball joint is still gonna be in the same place???
Randy'65 said:Why is it that when I mentioned this a couple weeks ago, I got blasted for it![]()
One thing though, if it is oly a 7" wide rim, you don't have as much backspacing, so you may not have a problem, right?
67efivert said:i understand what ur saying dodge but it didnt seem to help any on mine when i did it and also u got to think when the suspension articulates up and down its gonna go closer and farther away anyway like going over a speed bump at an angle one arm could move as much as 4 inches so its still possible fo it to hit the rim![]()
