  • SN95 4.6L Mustang Tech
will this set up mess my read diff
  • Thread starter Thread starter Mustanggt108
  • Start date Start date Jan 18, 2006
M
Mustanggt108
221
  • Jan 18, 2006
I'm ordering the NT 555R Drag Radial.First of all , are these tires considered semi-slicks??
I dont see the strip , i only do street racing.so i only need those tires to get a better grip when i shift from 1st to 2nd withought spinning that much like stock tires.Is this a good choice for my planing? I will never do hard launches from 1st . I will only shift hard from 1st to 2nd.That wont harm my rear end , right?
QU!CK
146
Charlotte, NC
Jan 18, 2006
  • Jan 18, 2006
If you don't plan on launching hard then you're wasting your money buying Nitto's.
-J
BooWFO
991
Louisville, KY
Jan 18, 2006
  • Jan 18, 2006
Nitto DR's are not a semi- slick to me that is an ET street.
Will you hurt your rearend with them doubtful with the list mods in your sig.
Although a little food for thought, DR's tend to stay kinda slick in cold weather. Also I know several people that run the nitto DR's at all 4 corners during the summer months.
LAST but not least street racing is wrong.
stangGT97
1,299
Boston area, MA
Jan 18, 2006
  • Jan 18, 2006
You could always get the non-drag radial version and save some money
M
Mustanggt108
221
  • Jan 18, 2006
which ones? you mean the Nittos , that says on them D.O.T approved?
all i need is semi-slicks ? which ones should i get?
M
Mustanggt108
221
  • Jan 18, 2006
what i mean is , will the grab like semi-slicks??
if you wanna launch using them , do you have to warm them up just like you do with slicks??
what i want is semi-slicks , if those are like that then i will get them...
sorry but my knowladge is bad when it comes wo tires. Some info would be great .thank you
stangGT97
1,299
Boston area, MA
Jan 19, 2006
  • Jan 19, 2006
If you do most of your racing on the street notnice: ) then stick to street tires, because I'm sure you'll be kicking yourself when a rain storm hits after you smoke Ricer Joe and you have to drive home. The nittos I was talking about are here
On a basically stock GT, those should be more than enough tire for you. Just pick the size you need and be on your way. Also look at some Good year F1s or Bf goodrich tires
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Jan 19, 2006
  • Jan 19, 2006
i personally wouldnt go with the 555r for street use. it has a very low tread life, and was meant more to grip at the track. be it as it may, itll grip better on the street than most regular street tires, but it wont last long.
i personally ran kuhmo ecstas in my gst. being fwd, i ate those up rather fast, they gripped well for the price. i got some toyo proxes off a buddy and man, night and day. when i do rims/tires, ill be going toyo's out back definately. i also have only heard great things about sumitomo's(or however the **** theyre pronounced) on the street.
and as always, if youre planning on racing, do it on some abandoned road that has room for error on both sides(not a country road with trees 5 feet from pavement on either side that love to catch cars with bad drivers). or a nice long 2 lane freeway in the middle of the night with no lights on either horizon.
btw, if you got teh 555r's, you might as well go to the track anyways, get some real numbers on how those tires put it down.
dollarbill
140
Decatur, IL
Jan 19, 2006
  • Jan 19, 2006
If your 1-2 shift is getting violent then back off some. Your not going anywhere anyway with the tires spinning. But I wish I had got some ET streets instead of regular street radials for the back. I never drive my car in rain or wet weather. If you have another car to drive in crappy weather then I say get some ET streets, they are the best hooking DOT aproved tire IMO.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Misfire or knock after ignition tune up
  • sleeprtsi
  • Jul 22, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 27, 2024
General karthief
