window squeek
bjgt2
60
ny
My passenger window squeeks going up. It does not do it much on humid or rainy days. How do i get new rollers, or is there an section to put oil on
thank you for your help
WTF I believe there is lots of us with the same problem. I took the door panels off one day and greased up all the parts that looked like they were moving, but it was only quiet for about a day... good luck.
okay i've figured this one out a long time ago. here is a few things you must do to make it stop squeeking. first thing is first get a can of lithium grease, being it's thicker and will last alot longer. take the door panel off, there is a main shaft that a platic retainer slides on, clean it all up make sure it's not cracked or missing. then lube it as the window goes up and down with wheel bearing grease i know i said white lithium but with this main one the wheel bearing grease will last alot longer. then find the little rollers or the tracks and lube those with the white lithuim and any other moving part you can see. and here's the thing not many people know about, check the outside of the glass, it might have score marks in it, if it does there is a little weather strip that is rubbing on the outside of the glass right in the middle. the way i fixed this was take off the belt molding right next to the window(one screw and it slides off) then you'll see where the little peice of weather stripping is rubbing, very carefully bend the pinch weld back so the weather stripping is not touch the center of the window. those steps should have taken care of the squeaking, if not it could be in the window motor or your just plain screwed.
power windows have a bracket on the bottom, with two pivot/lift points for thw window, the front one is probably weak or disconected.... i had a ho#da that did this for years tore the door panel up several times on it
