Windshield Washer Fluid Not Dispensing
Aug 16, 2011
9
9
Vegas
Just curious if anyone else has had this issue. I've had my 2015 GT for a little over a month now, and living in Vegas haven't had any reason to use my washer fluid until yesterday after it finally rained. Well, I pulled the handle, heard the pump, but got nothing. Not even a little bit out of either side. So, after I get it home in the garage, I look around the reservoir, everything's hooked up. Then I started looking at the nozzles(they snap right out of the hood FYI) When I got the Pass side one out, along with the line attached to it; I realized it wasn't connected to anything. Ended up having to peel back the heat shield a bit to get to where the line is supposed to connect, and it snaps right in. The Drivers side was fine, but wasn't working because it flows through the PS first. Easy fix, just wanted to know if I'm the only one that's had this issue so far. Thanks
