If you look at the base of the arm, you will see a little lock sticking up at the top of the base. You lift the arm off the windshield, use a small screwdriver to pull that lock out, towards the windshield, while pulling the blade away from the windshield. This will lock the blade away from the glass, then gently pull the base of the arm off the wiper trannsmission.
