wipers inop when wet
waxman
37
central il
i have an 88 lx,and the wipers only work on high,when its raining,etc.i put a good used switch on it, same thing.checked the plugs, grounds,for good connection. they work fine when its dry. still looking for a cure,thanks.
AeroCoupe
524
221
73
Jenks, OK
Fixed a buddy’s Fox with a similiar issue and it was the intermittent wiper controller. I believe you can bypass the box and then check to see if you have low and high speed. If you then have two speeds then you know the problem. If you don’t it’s most likely the motor itself or a wiring issue.
CAMTWO1070
163
48
38
NY
I had a similar issue in my 1992 8ft high junkyard monstertruck on 49's..Changed one of the wiper plugs that had a crack in it plus sealed the plugs w/ dielectric grease and the problem stopped....
When it works when dry and not when wet tells me that somewhere around the top power plug area you have a spot that allows water to cause issues on either the wiper motor or the plugs themselves...
Simply changing the $30 wiper motor should fix the problem...
Good Luck
CAMTWO1070
163
48
38
NY
When it works when dry and not when wet tells me that somewhere around the top power plug area you have a spot that allows water to cause issues either inside the wiper motor or the plugs themselves most likely due to a bad cowl to hood seal...
Simply changing the $30 wiper motor or the powerplug should fix the problem...
Good Luck
waxman
37
central il
Good Luck
30 bucks for motor? cant find them for that around here
