Wire Tuck, Engine Bay Smoothing Advice
I personally use a small butane torch for soldering. It heats the wire up ridiculously fast. You can just use one of those torch pocket lighters if you want. The only thing you have to be careful of is that you don't light anything else up if soldering in a tight area, but it still beats holding an iron on a wire. Don't forget the heat shrink tubing!
Small butane torch does seem to be the way to go and it saves me from having to buy a heat gun to melt the heat shrink tubing.
