Wiring Harness Madness
Special Fred
Chester, VA
I am converting this '84 LX over to '88 5.0 spec. It originally came with a CFI 3.8L V-6 and a C5. I'll be transplanting a V-8 from an '88 Mark VII LSC and an AOD from an '89 Town Car. My question involves switching over to an electrical system that will support the EFI. Since I'll be going with the stock heads & cam, the Speed Density system will be fine. I got a free dashboard with wiring harness from a guy who said it came out of a GT; however I have no way of knowing for sure. Even if this harness will work; the sheetmetal of these two engine compartments seems different, particularly the firewall. This harness utilizes a large round hole to pass through the firewall in the '87-'93 which the '84 seems to lack. How can I overcome this obstacle, and what am I to do about the engine bay layout?
Man, I shouldn't be posting a reply to this thread, but I am scared of you! :rlaugh:
:stick:
image.php
I hope you get some answers though.
Tim
So it appears there are two holes-one underneath the power brake booster (for the steering) and one under the heater core outlets; this one looks like a drain hole for the A/C condenser. Since I won't be using A/C anyway; guess that's the one I'll be using. Could be made larger if necessary. I wonder if this is the factory location on later cars? Guess I'll need to do a little research in the junkyard with the digital camera...
