Wiring Issues - New swap, Need Help
SILENTCARL
40
I have been trying to do this swap for the last three months. I had the new motor in the car in a day, but the rest of the time, has been a wiring nightmare.
We bought a break-out box for the EEC IV.
This is a '91 dis car with a swap to a distributer Merkur motor. LA3 , Large Vam.
Problems include no fuel pump, no injectors firing, electric fan comes on immediately when the IRCM is energized from ignition on.
I put a new IRCM in.
Please help! Any ideas will be very appreciated.
-Carl
I guess I deserved that...
I did search, and I did follow Stinger's directions to the tee. Then re-re-re-re-re-re-checked all of the pin-outs. Then I went and got all of the wiring diagrams for both the LA3 equipped TC, and my '91 LX. And went through that and double checked.
I wish I understood why it was doing this. I was just looking for any ideas you guys may have before I rip out the entire wiring harness and replace it with one out of a older dizzy car.
Stinger Intercooler piping with my Volvo front-mount and Ranger Radiator:
I would say you have some stray red/green striped wires in the harness that need to be soldered together. They are the signal return wires that go to all the sensors. When plugs are eliminated, the red/green wires are left open. Since they all run together in the stock harness, not doing so in the new "swap" harness will keep the injectors/sensors, etc. from being grounded.
Got it running. It sure is fun reading off of 3 wiring diagrams at once...
'86 svo harness converted to LA3 and placed in a '91 2.3 dis car.
It idles very rough. Almost like a super crazy cam in a v-8. It shakes the whole car. Don't understand that... Any things i should check on that? Any suggestions?
What do you guys think for timing, and base fuel pressure? Where should I be?
It was a simple problem that I am a little too embarrassed to tell you guys about. lol.
But, It runs fine. We have been finishing up all of the final wiring, but I drove it for the first time last night. I love that damn car. My truck is so boring...
Still, I set base timing at 10* and fuel pressure at 38 psi at idle. What should I be at?
