Wiring up reverse/neutral safety switches on a T5?
The NSS is only needed if you are using the EFI from an 86-93 Mustang. It has nothing to do with the starter.
Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
Diagram courtesy of Tmoss &Stang&2birds
attachment.php
See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars
See http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
The reverse light switch is on the side of the T5. It has two screw studs on it that fit a push on connector.
attachment.php
