  • SN95 4.6L Mustang Tech
wont idle when cold
  • Thread starter Thread starter cobrajeff00
  • Start date Start date Oct 18, 2005
C
cobrajeff00
12
  • Oct 18, 2005
I need some help. My 2000 GT poser will not idle when its cold. It just started doing it yesterday. It starts right up, but if you dont hold your foot onthe gas, she dies. Restarts fine, but continues to die untill the motor is warm. I would say anything under 50 degrees. Once its warm, it idles fine. Any ideas ?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 18, 2005
  • Oct 18, 2005
Try removing those Cobra badges...
Seriously though, sounds kinda like faulty IAC...
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Oct 18, 2005
  • Oct 18, 2005
Also, check to see if your MAF is oily--you have a K&N air filter that gets oiled after being cleaned. The oil blowby sometimes accumulates on the MAF and can (not will) cause these same symptoms.
C
cobrajeff00
12
  • Oct 18, 2005
where might the IAC be located at ?
timeless2
Admin Dude
202
154
the Shadow Gallery
Oct 18, 2005
  • Oct 18, 2005
It's the valve that mounts on your intake. Sorry, I don't have a better pic, as this is from a Bullitt.
BankBoyJim
18
Maine
Oct 19, 2005
  • Oct 19, 2005
I've got the same issue......
I've got a 99 GT with the same issue. I did look over the MAF and it looks clean. Is there any way to test the IAC? Did you figure any thing out, cobrajeff00 ? I've got alot of gas smell with mine, like the car is getting too much gas, not enough air ?
todd4566
1,075
California
Oct 19, 2005
  • Oct 19, 2005
I had the same issue with my car Jeff - a new Idle Air Control valve cleared the problem. The IAC accumilates carbon buildup over time, potentially causing it to stick. You can try spraying the IAC with carb cleaner, but your best bet is to simply buy another one. Auto part stores sell them anywhere from $50-60, or Ford for $70.
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
