my car cranks fine, but the spark from the coil to the distributor doesnt fire until i let off the key.
Whats backwards here? thanks
Whats backwards here? thanksI think RD and I are dancing around the same idea here. It sounds like a nice place to start (I am not familiar with 4 eye wiring enough to offer schematic assistance).OonDeanisS said:yes hissin, but i dont even know where the ignition switch is.
You probably have a Duraspark type distributor since the car runs a carb and not EFI. The trigger mechanisim is different between the EFI & Duraspark distributors.OonDeanisS said:it was a 4cyl. And I dont think any part of my car is Duraspark. My coil and ignition box are both MSD.
crazypete said:I wired the ignition to battery power with a manual trigger switch also tied through battery power and problem solved.so how did you do this?
crazypete said:Happened to me too. My Crane hi-6 lost power during cranking and would come on when put to run. My diagnosis: the starter was sucking all the juice out of the system. I wired the ignition to battery power with a manual trigger switch also tied through battery power and problem solved. Odd thing is, I can take the key out and the car continues running if I dont turn the ignition switch off.
