  • 1994 - 1995 Specific Tech
Wont start, Help Please!!
  • Thread starter Thread starter bondobeast
  • Start date Start date May 30, 2006
bondobeast
  • May 30, 2006
Hi all, i've about had it with my car.
My car died, thought i was out of gas, turns out im checking the basics and the metal portion of the rotary button had fallen off into the distributor, so I pull that out, am able to walk to pep boys and get another rotary button. The car at this point starts up like a champ.
So then im driving home, (did hear some whining, which i think honestly is another unrelated problem ) and it dies again. While waiting for triple A I noticed I unplug the coil and set the boot next to it and turned it over to see if I had any spark and there is no spark.
I've replaced:
-ignition module
-additional rotary button
-rotary cap ( MSD cap )
-ignition coil ( have MSD coil )
- I rebuilt the distributor 3 years ago when I got the car, to replace the stator.
It turns but it wont start. Any suggestions!? Are there any sensors, and/or and ECU fuse, or anything im not thinking of that could cause this? Also, does anybody know where online I can get ahold of wiring schematics/diagrams for ignition systems on a 94/95 5.0's? THanks in advance im loosing my mind over this thing
- Gordon
bondobeast
  • May 30, 2006
bump
94-302-vert
1,947
NE CT
May 30, 2006
  • May 30, 2006
Did you verify voltage to the coil?
95opal
5 Year Member
Nov 16, 2004
449
20
39
May 30, 2006
  • May 30, 2006
Even though you rebuilt your dizzy, whining from it is a tell tail sign that its done. I would check into a new dizzy. If you can verify that the whining is not coming from the dizzy disregard what ive said. good luck
F
fordtech28
312
Riverside Cali.
May 30, 2006
  • May 30, 2006
I'll bet its your distributor since you said it broke part of the rotor I would think it shaft is probably warped somehow and then messed it your startor again If I were you I would get a completely different distributor
Pokageek
2,767
MA, USA
May 30, 2006
  • May 30, 2006
My stator on my dist went bad on my new engine within days and it was brand new! Check that.
HISSIN50
34
129
May 30, 2006
  • May 30, 2006
What is a rotary button? Are you talkin about the carbon button under the top of the cap (that touches the rotor)? Or the rotor itself?
In any case, the replies have been good. WHen it wont start - this occurs when the car is hot? Grab a noid light and look for injector pulsing. If you dont have spark OR injector pulsing, the PIP is very likely the issue.
If you DO have injector pulsing but no spark, keep going through your ignition - the PIP would appear to be working.
PIP's do take a poop when they get hot (hence my asking above). Sometimes spraying electrical contact cleaner on the shutter and window dealies will cool the sensor (and kinda clean it, esp if your dizzy bushing is on the outs and allowing the PIP components to hit eachother and create carnage) and allow the car to start and run for a little bit.
Random thoughts. Good luck.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
